Warrior tire pressure....
Old May 20, 2002 | 10:03 AM
A2000's Avatar
We all started off on a big run yesterday, only for me to blow a tire in the first mile. I always run the recommended 3.6 psi in the tires, but they seem so soft. What happened was I hit a small rock and the tire was so soft that it folded against the rim and cut itself. After I patched it up I pumped all of them up to about 6 psi and had no problems for the rest of the day. Is it ok to run the pressure that high? It seems to make more sense on the rocky trails.
Old May 22, 2002 | 05:01 PM
dominatingwarrior's Avatar
I run 6 psi in mine with no problems.
Old May 24, 2002 | 12:34 AM
warrior620's Avatar
same here 5-6 psi. no problems
Old May 25, 2002 | 06:58 PM
A2000's Avatar
Thanks...I'll try that.
Old May 26, 2002 | 02:43 AM
Radman's Avatar
Higher pressure will give you a little better control. Less sidewall flex. I run with 6 psi all the time. It will also stop you from hitting the rim (bottoming out on the tire) on big air with hard landings.
Old Jun 6, 2002 | 03:51 AM
blazenwarrior's Avatar
5psi on the back and 6.5 on the front is what i use. works fine. tried at 3.5 and bead let out on a big jump landing put back to 5 and 6.5.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
