Dial A Jet
Old May 25, 2002 | 12:30 PM
pauli's Avatar
Has anyone installed a dial-a-jet kit on a Wolverine before ? Sounds like a good idea but I was wondering if it really works and is worth $80.00.
Old May 25, 2002 | 06:47 PM
Radman's Avatar
Just wondering why you would want to use that? These were used more in snowmobiles with 2 strokes than 4 strokes. Just get yours jetted and running good and don't worry about it. It gets a lot colder up here and guys aren't having any troubles, even at -30. So I would just save your money[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 6, 2003 | 03:48 AM
cruiser3's Avatar
Default Dial A Jet
I have installed Dial A Jets in 3 Wolverines. We ride from sea level to 8000 ft. They work great. Type "dial a jet" into the search category on this forum and see all the positive results. The only real negative posts I've seen have been from nay-sayers who freely admit they have never used Dial A Jet or one guy who got mud into the air supply of the Dial A Jet. I mounted my air supply near handlebar level so I've had no problem. I also am not a big mud fan since I live in Arizona!!
Old Nov 6, 2003 | 08:34 AM
NY02Raptor's Avatar
Default Dial A Jet
hehehehe here in NY you dont have much choice but mud... and my intakes where mounted near the handlebars on a my raptor.. still sucked in crap... oh well.. its not a think you want to use in wet conditions thats for sure
Old Nov 6, 2003 | 09:57 AM
Freez's Avatar
Default Dial A Jet
I believe you can buy small filters for the dial a jet called a snorkel kit. It will help to keep the mud and dust out, form the looks of it.
Old Nov 6, 2003 | 10:12 AM
cruiser3's Avatar
Default Dial A Jet
Where I have my snorkels located, you would be hard pressed to get mud and water in them----unless you were submerged in mud!! There has to be a place on the machine that will not get splashed by mud and it should be easy to locate.
Old Nov 6, 2003 | 12:01 PM
PredFan's Avatar
Default Dial A Jet
If you're adding a dial-A-Jet on your ATV, definitely get the snorket kit. The snorkle allows consistent clean air to flow into the carb - and remember the air from the DAJ is directly flowing air into the carb, not passing through the airfilter first. Consistent airflow from the snorkel through the DAJ is the best way to ensure top carb performance.
Old Nov 6, 2003 | 12:26 PM
DeuceCoupe11's Avatar
Default Dial A Jet
Could you just not route the hose into the top of the airbox?? If you get that much water it there you have other worrys.
Old Nov 6, 2003 | 04:01 PM
NY02Raptor's Avatar
Default Dial A Jet
cant route them into the airbox because they wouldnt work correctly.. they need to suck air in when you open up the carbs to give and extra squirt of fuel.. well when you suck all the air out of the airbox then they would starve and possibly suck gas up through those tubes... i have the snorkle kit (its all in a box now) and to be honest i drive through alot of water and mud and where i placed the snorkles i figured they wouldnt get as wet... (sandwiched between the gastank and a rubber mat that lays behind the radiator and ontop of the frame... mud/water still got to it... but again this is a raptor... not as water proofed as other atv's
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
