warrior trans oil
Old May 26, 2002 | 11:54 PM
warrior350megamax's Avatar
what oil should i use for my (93) warrior trans and how can i check to see how much to fill it? is there a sight glass? thanks
Old May 27, 2002 | 12:05 AM
02raptorboy's Avatar
your engine oil also lubes the tranny
Old May 27, 2002 | 12:07 AM
Thrust's Avatar
I thought you just filled it up almost to the rim? I don't know about warriors. But, try using a 10-30w oil.
Old May 27, 2002 | 12:08 AM
Thrust's Avatar
My bad I'm thinking about 2-strokes,D'oh!
Old Aug 16, 2002 | 03:31 PM
DesertBum's Avatar
Can you use regular trans oil (synthetic) for a 2 cycle engine? OR does it have to be Honda HP trans oil?
Ron
Old Aug 16, 2002 | 03:41 PM
TheRaptorMan's Avatar
I usually use just a normal 10w 30 on my old warrior, but most people that I know swear by the Yammalube (available at any Yamaha dealership)
Old Aug 16, 2002 | 03:51 PM
DesertBum's Avatar
Your atv is a 2 cycle?
Ron
Old Aug 16, 2002 | 03:55 PM
No its a 4stroke. Yamalube does make a 2 stroke oil (to mix with gas) as well as a normal engine oil ex. 10w 30
Old Aug 16, 2002 | 05:42 PM
2001atv's Avatar
I run 20w40 in the summer (Yamalube) and it will hold two full quarts and you should have 350ml left in the third quart for a total of 2500ml.
Old Aug 16, 2002 | 06:20 PM
DesertBum's Avatar
I am talking about the oil that goes into where the clutch and gears are for my 2 stroke. I have been using Honda HP @ $5.99 a quart. One quart is all she takes. Was wondering anything cheaper? I use AMSoil for my pre-mix though.
Ron
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
