how do i sup up my blaster
Old Jun 2, 2002 | 11:32 PM
needforspeed's Avatar
i want to make my blaster more power ful and have more speed with out boring it. any suggestions i already have an fmf fatty pipe and an fmf power core 11 silencer on it.
Old Jun 3, 2002 | 01:37 AM
mentalmojave's Avatar
v-force delta reeds or boyesen rad valve. clamp on air filter instead of the factory airbox,vitos degree key so you can advance the timing, shave a little off the head to increase compression. Any of these mods will help you out.
Old Jun 3, 2002 | 12:48 PM
copguy02foremanS's Avatar
put a 250r engine in it...
or you can 'sup' up your blaster by adding some speed stickers, those gain about 5mph, and some powerbands in the gas.
I have no clue what im talking about.
But I suggest seeing if a 250r engine fits. or an lt.
Old Jun 3, 2002 | 02:25 PM
timewass's Avatar
I would start by adding a pipe/silencer, airbox vents, larger carb, or just rejet yours, radvalve and you can usually get a port/polish done pretty cheap.
Old Jun 3, 2002 | 05:04 PM
Thrust's Avatar
In the June 02 issue of DirtWheels they hae an article called "How to make your Blaster Faster" If you haven't removed T.O.R.S the mag tells you how,and it only cost 10 bucks. It gives alot of tips on how to "sup up" your Blaster.
Old Jun 4, 2002 | 08:58 PM
thanks for the info.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
