warrior cams
Old Jun 7, 2002 | 11:18 PM
warrior4969's Avatar
if i add a new cam will i have to replace any other parts with it. and which cam should i get-powroll-webcam-4 stroke tech
Old Jun 7, 2002 | 11:34 PM
warrior007's Avatar
I have a webcam for topend with biggest lift I could get at .450" It made very nice gains on top but if I had to do it again I would get a midrange cam to put the power in a more useable range.
I also combined the cam with 12:1 arias piston, High-comp pistons and big cams go hand in hand and work together. The cam moves power through the rpm range from low rpm to mid or top end - it doesnt create any. You may have a loss of power down low with the cam and a high-comp piston will restore that power..
You will also have to get stiffer valve springs and better keepers to go along with any cam. High octane is required with the 12:1, preferably over 100.. I get by on 93 with some octane boost.
If I did both again, I would get a 10.5:1 piston and midrange cam.
Old Jun 8, 2002 | 12:08 AM
thanks man that is the info i was looking for. i have $360 to play with and i was thinking of getting a midrange webcam and a wiseco piston kit, valve springs and a cluch kit. are the pistons and cams hard to install
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
