Engine help please (PICS!!)
Old Jun 10, 2002 | 11:20 PM
binfordw's Avatar
This board gets alot of travel, so here goes--
I was told to try resetting my valve clerance to improve a cold starting problem.
This is on a 160cc engine- not OHC, 2 valve..
Would having the valve clerance set too tight affect starting? I am curious!!
Old Jun 10, 2002 | 11:32 PM
KNOWSALOT's Avatar
The Facility
Yes. Setting the valves too tight will cause it hard to start....or not even start at all.
Old Jun 10, 2002 | 11:50 PM
binfordw's Avatar
Why though?? Is it because it might be tight enough to not close the valve all the way?? I cannot think of any other reason?? HELP! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 11, 2002 | 12:03 AM
smitty911's Avatar
If the valves are to tight they will stay open and all the compresion will get by the open valves.
Smitty
Old Jun 11, 2002 | 12:07 AM
binfordw's Avatar
Well, okay.
I found out it needed a valve job by noticing that it wasn't sucking air though the carb, I put my hand over the carb and air was actually pushing out, so that told me the vavles weren't closing right..
Its got a good "suction" thru the carb, maybe just not quite enough or long enough to allow easy starting.. Okay- makes sense now. Hope thats what my problem is!
Thanks guys!
Old Jun 11, 2002 | 03:29 AM
binfordw's Avatar
Well- I checked my valves- and the intake did seem a little tight. So I loosened it up some, but it still won't start- I'm getting spark and even with spraying carb cleaner up in it- no go... I'm beggining to think I've had the timing slightly off this whole time- I need to go find out.
Could this be syptoms of bad timing?? Once started- it seemed to run well- Can Anybody help me out?
I just HAFTA get this thing going again, I wanna take it along on our next ride- that way if any Raptors or Banshees beat my Suzuki, They'll have to answer to the big bad 160!! lol [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 11, 2002 | 06:32 PM
binfordw's Avatar
Well, I checked the valves, and they seemed okay. The intake was a little tight, so I backed it off alittle.. I checked my timing again too, and it was "good". Still, I pulled till I was blue in the face with no results--- And then today I pulled it with my quad, and bam!- fired right up and actually ran good!
After I shut it off- it would fire right back up on the first pull!
After it cooled down though, same story- I was pulling and pulling with NO result..
Can anybody give me an Idea of what to try next??
Could be a bad sparkplug wire- It was shocking me- I have heard they aren't supposed to if they are good.(I also did a continuity check, and it did show bad, But I put a new wire on, and it still didn't start pulling the rope...)
Old Jun 11, 2002 | 08:00 PM
WyoDuner's Avatar
Sounds like low compression or weak ignition...
Old Jun 11, 2002 | 08:08 PM
binfordw's Avatar
Cool, I'm gonna go thru the ignition and check it all out
I am using a 6 volt automotive(tractor, actually) coil, you know, the kind that look like a pop can- and am wondering if that might have something to do with my problems..
How can I get a hotter spark??
It sparks good while the plug is out, but I know that doesn't nessecarily mean its strong enough for proper starting- is there anything I can try? A different plug perhaps? a different coil?
Is there a good way to check a coil for power output?
Thanks guys, keep the help coming!!!
Old Jun 11, 2002 | 08:27 PM
truckracer's Avatar
Since it started by towing it sounds like low compression.
