raptor carb question?????
float level should be 0.52" (about a 1/2 inch)with the carb upside down measure from the lip of the carb lift the float till it touches the needle (but not compressing it) and measure to the top of the float. I use the small ruler that came with my feeler guages (about 2" long). if your floats are off you can expect problems when you wheelie, climb steep hills, and sometimes on hard corners, usually you can smell the fuel from the overflows
toonces
10-16-2019 12:11 PM
