owners of blue wolverine,please read
Old Mar 9, 2000 | 09:52 PM
leoj12's Avatar
hi, I'm from Montreal Canada and I just bought a blue wolverine 2000 3 months ago. My problem is that the plastics start to turns white at many places. I would like to know if other people have the same problem. Is it cover by the Warranty. Yamaha canada are apparently aware of the problem but they don't want to cover it with the warranty.
Old Mar 9, 2000 | 11:36 PM
jettrax's Avatar
I noticed the same problem in locations where the plastic has been bent.
Old Mar 10, 2000 | 04:53 AM
GrizKo's Avatar
I have A '00 Kodiak with the blue plastic and have the same problem. I showed the dealer and they also told me Yamaha was aware of it,they told me Yamaha does not want to replace the plastic right now untill the problem is solved,because it will just do the same thing.They did tell me how to get the colour back take A heat gun and slowly heat the affected area moving back and forth slowly be carefull not to overheat the plastic.What this does is gets the pigmentation back to the area I tried it and it works to some extent,while it is no cure it sure helps the looks in the meantime.Another suggestion is make sure you get documentation from the dealer that you showed them you had this problem while the bike was still under warranty.
Old Mar 10, 2000 | 09:43 AM
Bruce's Avatar
The Blue plastic can be fixed with a heat gun. You must very carefully heat up the plastic from both sides and it will take out the white color. This is not the best of repairs, as it may tend to dull the finish, but if the plastic is all scratched anyway it looks lots better. You will see the white turn blue again as it heats up. I do this on my wolverine and banshee.
Bruce
2000 Banshee
99 400ex
99 wolverine
Old Mar 10, 2000 | 12:51 PM
jcsact's Avatar
I have a 99 Wolv. and my plastic is turning dark in some places on the corners. Would the heat gun deal work the same for me. Are they looking at all the plastic fenders for color change
Old Mar 12, 2000 | 11:39 AM
Kerplunk's Avatar
Do you guys park your machines outdoors in the sun or inside?
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
COFatboy
May 2, 2020 12:06 AM
gogogo
Oct 15, 2015 05:40 PM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
