grizz wanted to rev itself to death!
Old 06-17-2002, 05:59 PM
Kraw's Avatar
weirdest thing..went for the first real ride on the grizz this weekend. Bike performed great! ~90* out, high humidity.. lots of back woods riding... no vapor lock.
Get home after about 2 1/2 hrs of riding, park the bike. My bud wants to ride it, so he hops on, cranks, and VRRRROOOOOOMMMMM... reved to like 3/4 throttle! he promptly turned it off. Started it again, it was still revving pretty high, but not as high.
I washed the bike off, let is sit for maybe an hour, and it was fine afterwards. The bike has about 7hrs on it now. What could cause it? dirt on the carb, maybe on the throttle cable? the chock was working fine. Darndest thing
Old 06-18-2002, 02:54 AM
Kraw's Avatar
no one? Silverbear, where are you?
Old 06-18-2002, 11:07 AM
madhandlez's Avatar
that hppenend to me on my blaster but i think it was cause i left the choke out but i turned it off and kicked it went to full throtte without me givin it gas then as i was driven back it died out and wouldnt start so i had to pop it in nuetral and push it a mile and a half so it migha been the choke
Old 06-19-2002, 06:36 PM
Kraw's Avatar
also, another thing I forgot... it back fired really loudly after the hi idle thingy
Old 06-26-2002, 10:46 PM
Kraw's Avatar
bump, for great justice~
Old 06-27-2002, 12:27 AM
Frogman28's Avatar
Is the bike still doing this?
If anything, is sounds like the throttle is sticking. Might want to lube it and see if there is any change. You cannot always count on a properly lubed bike when you get it.....speaking from experience..lol
The only other thing that i can think of is, if you left the gas switch in the ON position, gas could have gravity fed into the head. I have seen this on alot of different motorcycles. If you dont shut the gas to OFF, then it will high rev until the excess gas is burnt off. JMO
Jonathan
Old 06-27-2002, 03:58 PM
SilverBear's Avatar
Kraw~
Haven't had that happen, but I would definately check the throttle cable.
SilverBear
Old 06-27-2002, 04:03 PM
MadBaja819's Avatar
Just a thought, if the bike continues to do this right on start up, then that is a sign of a leak on the intake side and it's sucking in air.
Old 06-27-2002, 06:55 PM
Kraw's Avatar
it happened right after a long ride. Lots of mud on the bike. I stop, kill it, jump off and me and my bud swap bikes.. it does it to him. My wife was standing right there, and said he never hit the throttle. I am sure the eng was still hot/warm. It hasn't done it since, but it was the first long ride we have been on
how would I lube the cable?
Old 06-27-2002, 06:57 PM
MadBaja819's Avatar
Take the cable off from the throttle and get some WD-40 with the little plastic piece on it and spray it down inside.
Quick Reply: grizz wanted to rev itself to death!
