engine builder question about raptor crank brg
my crank brg that is pressed on behind the timing chain gear has play in it,if you try to move the race up and down there doesnt seem to be any play but if you hold the race,or with the brg/crank assembly pressed in the case half, you can move the opposite end of the crank up and down considerably.is this normal or do i have a bad brg?my dealer didnt like it but the only way you can get the brg is to buy a crank half.he did have a crank brg he thought would have the same dimensions,yamaha #93306-30719.has anyone replaced this brg?if so what replacement number did you use?
