What are the first things i should get for a Blaster?
Old Aug 8, 2002 | 05:45 PM
WarriorMadness's Avatar
One of the best mods you can do to it is change the rear tires. Put on some 20s they will increase the bottom end. That new Toomey pipe looks great if it does for the blaster what it does for the banshee it should be a winner. I put raptor tires on my warrior and it really helped alot.
Old Aug 8, 2002 | 05:53 PM
KNOWSALOT's Avatar
The Facility
HYDRAULIC DISC BRAKE CONVERSION!!!!!!!
If you are buying a new 2003 model, this will not be a problem.
If it's an older one, do this before you do any serious mods.
Better braking makes you faster than a pipe would. Something to think about.
Old Aug 8, 2002 | 06:31 PM
spacollie's Avatar
A RAPTOR ENGINE.
Old Aug 8, 2002 | 06:43 PM
Ward660R's Avatar
I am glad you started this thread. What about Vito's pistons? Heres the deal a friend got a blaster for $200, it has a shattered piston and a hole in the case. The hole is fixed, I think, but we haven't decided on a piston yet. It already has pipe, filter, and reeds.
Old Aug 8, 2002 | 08:56 PM
  #15
Peltrax's Avatar
The vitos piston is supposed to be good,they claim it adds 5 horspower,but if i had a blaster in that condition id buy a 240 kit from them for 250 dollars instead....and what are you talking about???!?!Why would you seel a blaster so you could buy a mojave or 250ex?!?!?!??!!??The blaster is better than both in my opinion and even if you thought that they were better than the blaster they cant touch a modified one!!!No flaming,just roasting...
Old Aug 9, 2002 | 03:25 AM
  #16
raptor8's Avatar
Text;D sorry dont know how to use these tools yet.
Have enjoyed my raptor for a year now, and it got lonely. I knew it, and it felt better when i brought a new blaster home for it to chat with in the shed.....
boy that blaster is a BALLL! I need to connect with someone who cna lead me thru what to expect and what mods are the best! am in Cent OREGON, woods are closed right now, but will open....
Are there any tricke to properly breaking it in? best tires? my raptor has holeshot XCTs cuz of the sharp volcanic rocks..
a good deal? dealere wanted 3300.OTD for "02 [his last]
i offered him 2800. he called back and offered 2885.00 otd. tax, freight, tags, etc included. I JUMPED! thot i got a good deal. any body gonna upset me? hehe
A new blaster friend would be a big help! thanx! cya ;p
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 19, 2002 | 10:41 AM
  #17
Blastercrazy's Avatar
THANX GUYS!
Yeah im getting it in like 2 weeks now and it is a 2003![img]i/expressions/face-icon-small-happy.gif[/img]
I cant wait. i know im gonna get new tires right off cause i heard the Standard ones suck[img]i/expressions/face-icon-small-disgusted.gif[/img] Well then ill probablly get an fmf sst pipe and a silencer. but not to much after that. But im still listening to all your ideas! KEEP EM' COMIN![img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 19, 2002 | 10:47 AM
  #18
Hey RAPTOR 8, To brake an ATV in properlly you should just ride for at least 30 min a day! for about 5 days then it should idle fine after that!
Old Aug 19, 2002 | 01:09 PM
  #19
blaster19's Avatar
The stock tires and rims suck!! I just ordered Titan Fast Trekker's, front 21x7-10 and rear's 20x10-8 on Douglas .160 Wheels! Get a Toomey b-1! That's what i'm gettin here in a couple week's! LATA!!
blaster19[img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 19, 2002 | 04:27 PM
  #20
RC350's Avatar
For mods to a Blaster, I would recommend the following:
1. Replace the stock tires with a set of 20" square profile ties (ie - Holeshots, Razors, etc)
2. Toomey B1 pipe/jet kit/Air filter. This is a better pipe than the FMF Fatty (we switched my son's from the Fatty to the B1).
3. Replace the stock 13T front sprocket with a 14T.
4. Replace the stock reeds with a set of carbon fiber (we went with the VForce, but bolting on a set of carbon fiber reeds to the stock cage would work well also). May need to change jetting for this.
5. Install a +4 degree key from Vitos.
6. Have the flywheel shaved about 6 ounces. This will help acceleration.
7. When time and money permits, have the head shave at least 0.020" for increased compression. You can still run pump 93 with only shaving 0.020".
8. At some point, you'll want to have the cylinder ported. A good port job will really wake up the Blaster.
9. Remove the oil injection system and pre-mix your oil/gas. Parts for this can be had at your local Yamaha dealer (Yamaha actually sell a block off plate just for this. My cost for this at my local dealer was $18, not the $30 dollars being charged by most aftermarket companies)
10. Bolt on a 35 pwk air stryker carb along with a Pro-Design aluminum intake. Good power increase.
11. Perhaps prior to all the engine mods, you'll want to put aftermarket a-arms, and shocks for a better ride to handle all the added power. A lengthened swingarm would help also.
Regards,
Rog
