banshee wheel has a little play in it??
Old Aug 12, 2002 | 06:15 PM
RIDEORDIEYZF's Avatar
I've noticed that my 89 yamaha banshee frt wheels have a little play when i wiggle them back and forth... I don't if this is a common thing with the crappy j-arms or what.. does anyone know whats wrong?? Thanx
Old Aug 12, 2002 | 07:05 PM
desracers's Avatar
Sound like the ball joint is worn out.....
Which mean is new a-arm replacement.... Time to go shopping for a replacement.
Also see if the tie rod is loose, tie rod ball joint too.....
Old Aug 12, 2002 | 08:21 PM
o thanks, can u just replace the ball joint or do i have to buy a whole new top j-arm w/the ball joint.. also do u know where any sites that sell j-arm replacments.
Old Aug 12, 2002 | 09:29 PM
desracers's Avatar
Well the stock you just have to replace the whole a-arm not the ball joint. Which is the pity...
The aftermarket replacement a-arm, They are several places. One is Lone Star, Look into the dirtwheel mag. and see what they have on the ad. Also you might want to try out on E-bay and see who is selling of the J-arm.
Also look in to local paper ad too.
Good luck.
Old Aug 12, 2002 | 11:19 PM
rancherman350's Avatar
dont replace the ball joint! I would take a look at your front wheel bearings before u go and replace your j-arms!
Your ball joints shouldnt go bad unless you really beat the crap outta it. So look at the wheel bearings first lol it would be a lot cheaper then j arms
Old Aug 15, 2002 | 01:30 PM
OK this is weird. I just greased all j-arm bushings throught the little zerks and the wheels don't wiggle anymore. but i don't think hthere is anything wrong w/the bushngs cause i just replaced them like 3 months ago.. is there normally a wiggle in these bushings??
Old Aug 15, 2002 | 01:37 PM
bansheeguru's Avatar
Were the bolts slightly worn if you have a slight bit of wear the grease will fill the play and it wont wiggle until you ride again.but I would also check the wheel bearing for play aswell
Old Aug 15, 2002 | 02:42 PM
DennisC's Avatar
I just had to buy factory O.E.M j-arms for the front of mine. It cost me over 300.00 dollars. Good luck finding aftermarket ones, all I could find was companies that wanted to sell me conversion kits to a-arms. I would personally stay away from used parts, on something like this if you buy it used its probably pretty close to being worn out too, since there all goin to be about 12 to 13 yrs. old. Good Luck and have a great ride!
John Reed
Sep 9, 2015 03:46 AM
bmark0610
Sep 7, 2015 09:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
