More Dyno ?????'s
Old Aug 13, 2002 | 12:06 AM
RaptorRyan's Avatar
What SHOULD a piston, pipe,and ported Raptor make on a rear wheel dyno??
Old Aug 13, 2002 | 01:07 AM
Raptor74LV's Avatar
Mine will be Dyno'd this week in Vegas, I'll tell ya then. Yhe only other one I saw was at 43 RWHP. Doesn't sound like much does it? That cant be correct. Just remember, the a$$ dyno is the only one that really matters since no 2 dynos are the same due to many factors (temp., humidity, elevation, tire pressure, tire size / type, etc....)
Late!
Old Aug 13, 2002 | 01:12 AM
eRAPTOID's Avatar
74LV, did that one have a cam as well? or only what is mentioned above? What exhaust system did it have on it (if you remember)?
Thanks.
Old Aug 13, 2002 | 01:19 AM
Raptor74LV's Avatar
Toid, Actually its my bro-in-laws so Ill let him tell ya. Both bikes are basically the same, jetting a little different, I have an e series wb full pipe and his has a r series wb full pipe. Ill let him tell ya the rest
Old Aug 13, 2002 | 01:24 AM
RaptorRyan's Avatar
Soooo.... Raptor74LV what does your @ss dyno say????
Old Aug 13, 2002 | 01:35 AM
eRAPTOID's Avatar
74LV, you expect yours to be pretty darn close to the same then right? That's not bad RWHP. I see 686's with just over 50,,,, sooooo, it's not all bad!! I'm happy with those kind of #'s. Like everyone else has said, the ole A$$ Dyno says it RIPS!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 13, 2002 | 02:19 AM
THEMOOSE's Avatar
The only way you can compare dyno numbers is diffrent quads on the same day one right after the other by the same operator on the same dyno, & then only if the weather hasn't changed any between runs.
I got 43.1 HP on a stock Raptor with a Sparks X6 & dynojets.
I've seen numbers not much higher than that on built 686's.
The A$$ dyno & a stopwatch are the best ways to tell HP gains.
eRAPTOID, How do you like the new & improved TOID?
Old Aug 13, 2002 | 02:20 AM
newraptor2000's Avatar
All I have is a slip-on, Pro Design filter set up, and jetting and I'm at 42 HP. One with a high comp piston has got to be higher than that.
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
BlackHawk
Jun 9, 2001 04:13 PM
