how do you expand a blaster motors life???
Old 08-17-2002, 04:42 PM
liftkit's Avatar
What are the best things to do to a blaster motor to get long life out of them? what type of pre-mix, would yall recomend with ratio.
My blaster has a Vitos 240 kit,Boyesen reeds,jet kit,clamp-on air filter, and DG header and silencer. I race Hare Scramble races.
Old 08-17-2002, 10:40 PM
lonestarbanshee's Avatar
The very best way to extend its life is to not ride it...
If you dont have injection block off kit, buy one. Then start mixing 32:1, with Bel-Ray, Maxima, or Klotz.
Old 08-17-2002, 11:20 PM
liftkit's Avatar
I have not rode the blaster with the 240 kit yet. It was bored 80 over when I bought it and I blew it up in 2 weeks running 24:1 ratio. The guy at the shop suggested me to put the 240 kit in it but it is also getting a new hot rod connecting rod and clutch. I sand blasted the head and jug to keep the paint from holding in heat and I am trying to rig a fan to help cool the engine.
Old 08-18-2002, 04:35 AM
BlasterCW's Avatar
i am a blaster god. sleeve it to 40 over and no more. second,run 93 octane and nothing under because 93 burns cooler.mix 36 to 1 and it will be fine.32 to 1 is too much oil.you wont need to worry about a fan!!!!!!and use klotz super techniplate.
Old 08-18-2002, 02:48 PM
450HondaForemanS's Avatar
listen to him. He is a "BLASTER GOD!!!"
Old 08-19-2002, 11:44 AM
95wolv's Avatar
I agree with almost all of what CW has to say but one: keeping close to stock is your best bet for long life,but unless you run a high compression piston,93 octane would eventually cause some problems.Higher octane slows the flame front in the combustion chamber to prevent the random 'explosions' that cause pinging in a high compression engine. In a stock or near stock compression engine, the additives in the premium,or race gas would not get burned because of the lower chamber temp,and start to build up in the cylinder and the piston. It could even get to the point of making the rings stick from deposites. So, yes, for long life,keep it sane on the mods,horse power is real fun, but the cost is more maintenence and possibly shorter life between rebuilds,but hi octane is not required unless you bump the compression up quite a bit.
Old 08-19-2002, 01:06 PM
yamblaster98's Avatar
The only way you can keep the blaster going forever would keep it relativley stock, take the oil injection off and mix 32:1, change the trans oil regulary and not to run the snot outta it. I know "The Blaster God" would prob not agree with me but owell. Also i personally for my trans oil use belray and for pre mix i use yamalube, both work great.
Old 08-19-2002, 01:13 PM
RINCON's Avatar
i always thought higher octane burns cleaner?? (i'm not talking race gas here) all small engines call for premium (supreme) pump gas. race gas burns a lot hotter (with high comp piston) not cooler!
Old 08-19-2002, 01:23 PM
Raptoryfn660r's Avatar
RIP Dear Friend
<< The very best way to extend its life is to not ride it...
LOL----That's the best answer yet.
Chet[img]i/expressions/face-icon-small-happy.gif[/img]
Old 08-19-2002, 07:45 PM
yamahagye's Avatar
Well rincon, i think you are mistaken about race gas running hotter. It is just harder to ignite than regular gasoline and sometimes comes with additives like lead.
Liftkit
If you want your motor to last a long time, Take off the injection system and run AMSoil 100:1 premix at a 50:1 to 70:1 ratio.
JaMeS
Quick Reply: how do you expand a blaster motors life???
