Warrior Hop-Ups
Old Aug 26, 2002 | 11:01 PM
WarriorMan05's Avatar
Hi, I am looking for a way to hop-up my 2002 warrior. All I have on it now is a jet kit and an air filter. I was looking into an oil cooler from FST or whatever that place is. I am also thinking of getting an FMF pipe, how much do you think this would help.
Thanks for any replies,
Josh
Old Aug 27, 2002 | 12:10 AM
2001atv's Avatar
I jetted the carb, installed the pro design w/uni filter, vented the air box (homemade 7" diameter), and installed the big gun. All this and the 400ex will pull a little in a drag, if we run to 6 gear they have about a 2 1/2 to 3 quad lead. But in the woods they don't go anywhere!
Old Aug 27, 2002 | 09:16 AM
I also want to put Holeshot's with Beadlocks on it. Would this be any performance upgrade, better handling, what?? What about a high-comp piston, cam, and valve spring, what am I looking at there?? If I just do airbox mod's and the oil cooler, what jet should I put in there??
Thanks for any help
Josh
Old Aug 27, 2002 | 09:42 AM
WarriorManiac's Avatar
WarriorMan,
A pipe, rejet, and airbox mods/filter are the first I would do to your Warrior. This will improve power tremendously. Probably best bang for the buck. If you are running the factory tires, a set of HoleShots/Razr's will improve your handling and traction (BIG DIFFERENCE). The stock baloons on the Warrior are awful. After these things the next steps if you choose would be wider axle/spacers and shocks to improve handling. Higher compression Piston/Performance Cam/Springs or Big Bore Kit to further improve the performance.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
