Lid or not to Lid
Old Sep 9, 2002 | 03:32 PM
jameswilliams's Avatar
Has anybody tried this airbox mod form EHS? Is it any good? I would be running a K&N with a yoshi slip on.
EHS airbox
Old Sep 9, 2002 | 04:15 PM
rennym's Avatar
I run with no lid, and in combination with the pro design flange and foam filter, jetting, and CT Exhaust, the difference is night and day.
Unless you ride in mud/water, lose the lid..... Even splashing isn't to bad as the oiled filter repels the water for the occasional light splash. If you are submarining it, you have the wrong machine anyway.
RM
Old Sep 9, 2002 | 09:39 PM
wshrdskin's Avatar
Toid, did you get the K&N with that pro design? Thats what I have, its great. Less mess when cleaning and flows more air IMO. It filters just as good as foam IMO. I never run with out the outerwear though.
Old Sep 10, 2002 | 12:56 PM
garyc660R's Avatar
I have noticed on my prevoius stock cam and compression Raptor, turbulence was evident with the lid removed at lower rpms......I wound up having to lean the needles for proper operation. Now, with more cam and compression, this is not the case, I have richened the needles back up.....apparantly the higher compression helps too smooth out the turbulence issue. Thumbs up!
Old Sep 10, 2002 | 01:05 PM
  #15
RaptorRyan's Avatar
Thanks for the input guy's!!!! Looks like I'm sticking to topless!!! Hey if it aint broke why fix it!?!?![img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 10, 2002 | 01:53 PM
  #16
FASTRAPTORMAN's Avatar
I was thinking about taking the lid off. With a 01 Raptor that is Sparks piped, timing advance, and K&N air filter at about 500 ft elevation, where would you start with your jetting? The Sparks web pages suggested 27.5 pilot jets, DJ148/DJ150 main jets, and 2 1/2 turns out on mixture screw. What about Dynojet needle location? I thought most people left the stock pilot jets in and used like a 175/180 mains. Any recommendations would be appreciated.
Old Sep 10, 2002 | 06:31 PM
  #17
eRAPTOID's Avatar
FastRaptorMan, I have about the same question!
I am at less than 1000' and have the mods you see in my sig...
...and here is my current set up: DJ150/155 - DJ needles at 5th clip position down from top - Air/Fuel mixture screws at 3 turns out.
My question is, is this enough without the lid? The needles are 1 clip richer than what DJ recommends before the cam and piston. My plug looks a little leaner than I "usually" run it in the past. But not white.
What is everyone else running without the lid and with the Dyno kit????
Gary, are you using the Dyno Kit? If so, where do you stand right now?
RR, how about you - where do you stand?
Anyone???
"TOID"
Old Sep 10, 2002 | 08:30 PM
  #18
wshrdskin's Avatar
Toid,
Foam or K&N on your new pro design?
Also, you have a piston and cam, so your mods are different. I run the dyno jets 148/150 clip 4th groove and stock pilots 3 and 3 1/4 turns out. 0-1500' rideing mostly.
Old Sep 10, 2002 | 09:03 PM
  #19
RaptorRyan's Avatar
TOID... Here's what's been working for me at 2000ft 146/148 mains, clip 4th from the top screws 3 turns out. This is where it get's a little gray I have modified (drilled) pilots so I don't know exactly what size they are but they are larger than stock. No lid with K&N and outerware running race gas. Hope this helps!!!
Old Sep 10, 2002 | 09:19 PM
  #20
Griffbambino's Avatar
Unless you live in the desert I would say keep the lid. But, cut a huge hole in the lid and then cover the hole with a water proof outerwears fabric and remove the snorkel. Rejet(preferably with a dynojet kit stage two). Easily will boost horsepower three or four ponies.
