banshee transmission?
Old Sep 13, 2002 | 03:33 PM
jeff1's Avatar
does any one know how much time it would take to install a transmission in a 93 banshee. also is it very complicated.
I am about to buy a 93 banshee it runs good but it only has 1st gear left the rest of the gears won't work. i am assuming that it needs a transmission am i correct.do you think that $500 would be a good price for this atv.
Old Sep 13, 2002 | 04:08 PM
garyc660R's Avatar
IMO, the Banshee is a piece of cake to split the cases. Take the case bolts out and roll the top end forward with the crank alltogether! That baby splits horizontally! No top end gaskets needed (asuming you are not in need of a top end refreshing).
If it starts easily with a couple of kicks and is'nt destroyed, it's worth it in my opinion. Nit-pick the atv and try too work down from $500.
Old Sep 13, 2002 | 05:28 PM
AlkyBurninX's Avatar
When you say they don't work, are they stripped? Does it just not want to shift? If it just doesn't shift, it could be as simple as the stud on the shifting mechanism is broke off, shift fork bent, shift rod bent, shift star bolt backed out, or etc. Where are you located? If you don't by it, I will be interested if it is close.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
