banshee gear oil
Old Mar 24, 2000 | 10:20 AM
travsbanshee's Avatar
hello, i have noticed a small leak of gear oil coming from the seal around the shaft on the front sprocket on my 99 banshee. I was wandering if anyone else has had this problem, and if so, how hard is it to replace this seal? Thanks.
Old Mar 24, 2000 | 11:43 AM
sAyIt_fmf's Avatar
I had the same problem...... $13 for the seal... and it pops right out for a quick easy install.
good luck
Old Mar 24, 2000 | 12:11 PM
i was told that i have to break into the case. im guessing that that isn't true.
Old Mar 24, 2000 | 12:27 PM
sAyIt_fmf's Avatar
If the problem you are talking about is 'Oil coming out around the shift shaft' then you do not have to touch the case.... Take off the chain and sprocket so you can see it good...drain your oil....get a pair of needle-nose pliers and pull out the old seal ( mine popped right out). clean all around the opening and put in the new seal....
It really was simple...took no time at all. and it does not leak anymore.
If the shaft is bent...then you have another problem...and you will most likely end up inside the case. If the shaft is not bent...then go with it.
Old Mar 24, 2000 | 03:40 PM
thanks for the input. I just called the dealership, and they happen to have it stock.. 6 bucks!!!
Kaleb_00
Jun 1, 2016 09:15 AM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
