Fuel Question
Old Sep 13, 2002 | 06:10 PM
Ward660R's Avatar
A freind of mine is building a high comp and cammed motor. How do you know what the octane rating should be? Do you just try various levels or what? And do you want to run the lowest octane possible or run it higher than needed?
Old Sep 13, 2002 | 08:05 PM
RacinJason's Avatar
By Running a fuel with to low an octane rating you can cause detonation which will lead to major problems. The higher an octane rating the slower the fuel burns. The best octane is the lowest you can get without causing pre-ignition. Try some vp c12 mixed 50/50 with 92 and test her out.
Old Sep 13, 2002 | 08:40 PM
hot_shoe_cv's Avatar
My understanding is that with a compression ratio of 11 to 1 or higher, race gas is necessary. If the ratio is below that, he may get by with 92 octane, so it would be wise for your friend to determine exactly what his ratio will be.
Old Sep 13, 2002 | 08:44 PM
RaptorRidrTX's Avatar
With 11:1 you can run 93 octane just fine. I know a couple people that do. Above that, yes you need to run a higher octane fuel like race gas.
Old Sep 14, 2002 | 05:23 PM
Ward660R's Avatar
Thanks everyone.
How do you know how high to go? I know if you go to high you will lose power.
Old Sep 14, 2002 | 06:18 PM
spacollie's Avatar
Something else to keep in mind is the higher the rating the cooler your engine will run.
Old Sep 14, 2002 | 06:28 PM
velocityraptor's Avatar
Ben,
What compression ratio are you looking to run.?
Kyle5050
Dec 13, 2019 04:25 AM
mtdewmn
Jan 19, 2017 12:13 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Mikea1978
Jul 4, 2015 12:37 PM
