Warrior Axle Question
Old Sep 16, 2002 | 06:25 PM
Troy125's Avatar
Anyone who has ever changed the Axle on a Warrior, I could sure use some help. I got a DuraBlue, Heavy Duty Axle. I just need some tips on how to put it on, and especially be able to tighten the chain afterward> Thanks
Old Sep 16, 2002 | 09:41 PM
WarriorManiac's Avatar
Not to difficult actually. Remove both wheels, hubs and brake caliper. With big wrenches or in my case pipe wrenches remove the 2 lock nuts next to the chain sprocket. Now beat the axle out toward the brake side. This was the hardest part for me, got to protect the hub nut threads and spline if the axle is worth saving. I put an old hub on, then put a large socket over the nut and beat the hell out of it. It was Tight!. Just reverse everything going back in. The durablue basically slide back in. No beating required. Good Luck!
Old Sep 19, 2002 | 08:52 PM
RaceWarrior350's Avatar
i took mine off god it wieghs a friggin ton. was a big pain in the butt good tip have some help around to hold it so it wont fall on ur foot.
Eshelman
88 Warrior
K&N Air Filter
No Airbox
Pro Circuit T-4
Duro Rear Tires
DP Race Brake Pads
Fresh Rebuild
DG Nerfs W/ Red Web
Plastic Redone
99 Blaster
Fatty Gold Series Pipe
Power Core 2 Silencer
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
toonces
Aug 5, 2015 05:55 PM
