Next Best Mod For A Blaster...?
Old Sep 16, 2002 | 09:47 PM
FmFMan909's Avatar
What is the next best mod for the blaster after FmF pipes and itp tires???
Old Sep 16, 2002 | 09:51 PM
DaLakotaMaster's Avatar
boost bottle
Old Sep 16, 2002 | 09:54 PM
dillas23's Avatar
The best mods would be a reed spacer and new reeds, followed by a bigger carb. The boost bottle is a waste of time and not enough gains to offset the price.
Old Sep 16, 2002 | 09:56 PM
YFZRacer's Avatar
toomey pipes no just jokin fmf are pretty close to toomeys they just have a little less top end and mid. I draged a fmf fatty piped blaster with the exact same setup as mine (same gearing and tires) and beat him we were close at the start and then i started pulling away in the end it was fairly close tho. you might want to widen and lengthen it to make it more stable a air filter would help and i suggest takin off the air box and use an outerware or atleast drill holes in the cover just make sure to keep it clean . i've herd reeds help a bit in the bottom end. you can buy a vito's piston which is spose to add 5hp or you could go with porting and all that stuff. Or the biggest step is to get the big 240 Ct racing kit that comes with everything and have 40hp
Old Sep 18, 2002 | 12:10 PM
kevlt250r's Avatar
I have extended a arms and k&n filter if you are interested. all are in new condition.
Old Sep 18, 2002 | 02:53 PM
2001atv's Avatar
How much for the a-arms?
Old Sep 19, 2002 | 01:04 AM
2fun's Avatar
Get a K&N filter, remove the airbox, get aftermarket reeds, and rejet.
2001YamahaShee
Jun 17, 2014 11:52 PM
Leines
Jul 14, 2010 12:49 AM
Badazgt
Jun 25, 2009 10:00 AM
ghettoblaster
Jan 22, 2007 08:28 PM
