Will the Trinity get that much more?
Old Sep 19, 2002 | 02:45 AM
BlueRulez's Avatar
Will the Trinity 686 get me much more than keeping the stock bore, going with a higher compression piston, stage II webcam, and getting the head ported?
Old Sep 19, 2002 | 10:21 PM
BlueRulez's Avatar
Okay...I think it's time I call them and get some numbers. Looks like I'm gonna have about $5k to play with in the near future.
Old Sep 19, 2002 | 10:43 PM
14mins's Avatar
Bluerulez- Just get a regular port job. I think they take more cc's out of the combustion chamber with the pro-port, a 12-1 piston, lightened,deburred and coated, a 736/737 web cam, and valve springs. If you get the 696/697 do not get the dual rate springs. That cam does not reguire them. Dual rate springs steal HP, only use them if you need them. Get the pipe.
Old Sep 19, 2002 | 11:20 PM
wshrdskin's Avatar
Bluerulez,
I shouldn't be saying this but, give sparks racing a call. I was at Pismo this last weekend. There was a Trinity 727 with stock carbs and a Sparks 690 with FCR carbs. I was playing at comp hill and told the sparks guy about the trinity guy. He went to the drag area to see if he could hunt down the trinity guy. I came along a short time later and found them talking at the end of the drag lane off to the side. I rolled up and made a comment that "I see you found the trinity guy" The trinity guy chimmed in and said that the sparks guy smoked him bad. It apparently wasn't even close. I know trinity has better turn around times and makes a good dependable kit. Just throwing this out FYI.
Old Sep 19, 2002 | 11:46 PM
14mins's Avatar
I was out running a trinity 720 on alky at Litttle Sahara with the new 686 on race gas. He was mad. He was from missuori. I repeat that you have to make sure everybody knows what you expect from the motor. Horse power is not cheap.
01blaster
Jun 17, 2005 12:48 PM
x250rDude
Oct 10, 2000 07:28 PM
BansheeBrad
Jul 24, 2000 01:27 PM
brandon
Mar 29, 2000 03:40 AM
