port and polish
Old Sep 22, 2002 | 05:46 PM
bansheewarrior's Avatar
I've got my shee torn down to the crank doing some repairs and while I'm down I was thinking of getting a port and polish done.Anyone who as already had it done-who did it for you,where you happy with the work they did and what did it cost you.Any imput would be great thanks
Old Sep 22, 2002 | 07:24 PM
yamblaster98's Avatar
a good place to send out for port and polish work would be trinity racing. Go to trinityracing.com for prices and different types of work that can be done.
Old Sep 22, 2002 | 07:42 PM
THEMOOSE's Avatar
So your trying to catch back up to Raptiod huh!! LOL!!
I used Port Works to do my 250R cylinder.
They are local (Tulsa) & race at Atoka with me.
It was less than $200 if I remember right & it made an amazing diffrence.
I had a Dune & trail type porting & it ripped.
They can do from mild to wild.
They do all kinds of Shee work From stroker cranks & override trans to pipes & porting.
Old Sep 22, 2002 | 08:34 PM
Thanks moose i'll be calling them tomarrow.No i'm not trying to catch up i just want my banshee back up to par.remeber when my intake boot got lose on me last spring down there?it's just been getting worse and worse so i tore it down last week and that piston and wall on the right side is trashed hell it looks like it's even been getting fire on the bottom of the piston where it's going around the piston in all the groves in the wall.I bought new juggs and i thought i do alittle something while it's all torn apart.
Old Sep 22, 2002 | 09:10 PM
My99Banshee's Avatar
Well if you have it apart, spit the case and have the crank welded
before it's to late! if your going into porting without a welded crank you'll be sorry! A stock crank is just pressed together and to much power will spin the crank apart and destroying your motor and trans
Anything more than a set of pipes needs a welded crank.
Old Sep 22, 2002 | 09:28 PM
ryenol's Avatar
Moose is right, Portworks does good work. My friend had some work done on his, then he dropped a cylinder, and Darren at Portworks helped him out, and he will answer just about any question you can ask. My friends Shee now runs like Osama is from our troops.
Old Sep 22, 2002 | 10:15 PM
Sandgod's Avatar
Pricing & Builder
Old Sep 23, 2002 | 12:25 AM
THEMOOSE's Avatar
Portworks will do a good job for you.
Yea that sand in the cyl suks!!
At least you get to make some improvements now.
It swure lasted a while since last spring.
Ask Darren about what else you should do. Since it's gonna be down for a while you may as well check on the welded crank. I don't know much about Shees but it sounds logical.
Old Sep 23, 2002 | 12:49 AM
quadzilla499's Avatar
Check with either Rudy Kurtz or K&T performance. They build some fast reliable motors.
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
