97 wolverine leaking rear differential fluid
Old Sep 23, 2002 | 04:13 PM
mrsnooka's Avatar
This just started happening. Its not leaking from the differential. Its coming out of the overflow tube. I get a decent size puddle after every ride? What does everyone think?
Old Sep 23, 2002 | 05:06 PM
95wolv's Avatar
Did you just fill or add to the rear end? overfilling is easy,and when you ride,it heats up,expands,and goes out the overflow.
Old Sep 23, 2002 | 06:40 PM
chad400ex's Avatar
Same thing happened to me on my 1998 Wolverine. Right after I had it serviced by the local dealer. They had overfilled the rear diff. Make sure you re-route the overflow hose, because mine always dumped ontop of the carb if it was overflowing. I ended up routing it up the rear subframe, so that it would drip on the swingarm instead of all over the carb and engine. I serviced it myself the next time, and it never overflowed again.
Good Luck!!
cornermike
Aug 10, 2016 06:47 AM
robert301972robert
Aug 30, 2015 11:34 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
