web 736/737 vs hot cams stage II
Old 09-30-2002, 11:54 AM
layjzay's Avatar
I replaced a 736/737 web with a stage II cam friday night in my trinity 686. The bike is much quicker in the mids and top end. I have a friend with a banshee that would easily pull away from me when he hit third gear with web cam. Well, that is not the case anymore we are dead even throughout the run.
Has anyone had any clearance problem with the valve stem seal on the center valve like the directions are stating?
Old 09-30-2002, 12:51 PM
DollarBillz's Avatar
no there are a few bikes down here with stage 2
Old 09-30-2002, 06:38 PM
6ppc's Avatar
I went to the hot cams website and it indicated that I would have to run 95 octane race fuel with their cams for the Raptor. Is that really necessary? I run avgas in my LT500 because I've raised the compression considerably but with a stock piston in my raptor couldn't I use pump gas. I ride mostly at the dunes in Idaho and Utah with the elevation near 5000 ft. I wouldn't mind raising the compression also but I want to keep running pump gas on this machine. Premium pump gas in Utah is only 91 octane.
Old 09-30-2002, 06:45 PM
Ward660R's Avatar
<< Has anyone had any clearance problem with the valve stem seal on the center valve like the directions are stating? >>
Good question. I have been waiting for a call from Kibble White for a few days now with no luck. I have been told no problems but I would measure to be possitive.
Old 10-01-2002, 06:13 PM
swytak's Avatar
There are some tests for precations you should take. PM me and I will explain!
If you don't do the measurements to make sure of proper clearance, it could be bad news for you at high rpm's.
Scooter's Shop
23
10-22-2015 07:04 PM
XxS0ccerstarxX
09-24-2015 05:38 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
XxS0ccerstarxX
09-08-2015 12:02 AM
Elkaholic
09-06-2015 02:44 PM
Quick Reply: web 736/737 vs hot cams stage II
