banshee low end
Old Oct 6, 2002 | 05:42 PM
JohnJAbood's Avatar
b]what should i do to get more low end out of the banshee for woods ridding and deep trail ridding, tight trails. anythoughts. i was thinking gearing.[/b]
Old Oct 6, 2002 | 08:56 PM
Peltrax's Avatar
Things to help low end wood be a smaller front sprocket and higher compression and a low end pipe and port job,adding tires with tracion will help to!
Old Oct 9, 2002 | 01:37 AM
SomeCrazyMexican's Avatar
Default banshee low end
I got an amplink and that thing helps out ALOT on low end.
Old Oct 9, 2002 | 01:19 PM
WyoDuner's Avatar
Interesting.... I wouldn't think a device that sucks up 4 HP would help the low end very much?
Peltrax covered it pretty well, compression, low-end pipes and port and gearing. Advancing the timing 4 degrees should help some too.
Old Oct 9, 2002 | 05:41 PM
727Banshee's Avatar
Single Carb to get more bottem end
Old Oct 10, 2002 | 01:28 AM
How does that thing suck up that much horsepower? They get alot better grip on the ground!
Old Oct 10, 2002 | 12:39 PM
WyoDuner's Avatar
I forget where, but one of the performance shops dynoed a Banshee before and after putting the Amp link on and it lost 4hp. There's aquite a bit of drag with the extra chain & sprockets. While it may help traction (I don't know) it does take a considerable amount of power.
Old Oct 10, 2002 | 05:11 PM
I was reading in Dirt Wheels once and it said that the amp link was one of the best bolt on products you can get. Is that just there opinion or what?
Old Oct 10, 2002 | 05:33 PM
WyoDuner's Avatar
Well, I don't use one but it is supposed to help with traction and avoids the issue with the chain tensioning the suspension under power. The drawback is that it robs power and adds mechanical complexity.
Old Oct 10, 2002 | 08:38 PM
Peltrax's Avatar
Maybe the amp link affected the way the power was put on the dyno??i dunno??ANyways if you want EVEn more low end you can get the cingle carberator from trinity i think its like 350$$$$
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
