warrior
Old Oct 8, 2002 | 04:00 PM
bombrider's Avatar
Is the warrior reliable???
if not what are its problems???
thanks
Old Oct 8, 2002 | 07:17 PM
warrior350megamax's Avatar
Default warrior
yes the warrior is pretty reliable. The only constant problem that I have had with mine is the outer tie rod ends break a lot and they're 40 bucks a pop! Get beefed up ones and that solves that problem.
Patrick
Old Oct 8, 2002 | 09:42 PM
95Warrior's Avatar
Default warrior
The later ones (1992ish and on) are pretty much rock solid, not much you can do to hurt them. No changes either, except for the plastic color from year to year. No problems really, just "areas of concern", such as a poor airbox design and a poor chain adjustment design. The airbox is easy to fix with a ProDesign adapter with your choice of air filter, and the chain adjustment, take your time and Loctite it to hold it.
Old Oct 9, 2002 | 08:59 AM
bombrider's Avatar
Default warrior
Thanks
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
