Stage 1 or 2
Old Oct 16, 2002 | 08:01 PM
LOWBOWTIE's Avatar
Default Stage 1 or 2
Raptor cam that I have is the small one that ALBA sell with the piston & cam kits. I have 11:1 piston, K&N, White Bros Exhaust, Dyno Jets and no porting on the head. Is it O.K. to use the stage 2 without the porting,or should I stay with the stage 1. I Have to do something the WEB cam that I have is crap![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 17, 2002 | 05:24 AM
swytak's Avatar
If your "competint" enough to do some minor head work, go biggger.... Stage-2. If not, atleast go WebCam 737 grind.
Old Oct 17, 2002 | 05:31 PM
LOWBOWTIE's Avatar
what parts of the intake and exhaust ports would a competint person look at? Is it just cleaning up the runners or would I be taking out a certain amount of material? If it's pretty simple I'll takle it but if its tough I might sent the head to Trinity or someone that has had sufficient exsperiance with Raptors. Any guess on what the average cost on just the head would be?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 17, 2002 | 06:37 PM
eRAPTOID's Avatar
Three to four hundred bucks will get you a port and polish, depending on where ya go!
"TOID"
Old Oct 18, 2002 | 01:40 AM
swytak's Avatar
Valve guide work "might" need to be done to get to the correct clearance as called for by Hotcam for the Stage-2.
Trinity is currently testing the stage-2 cam and I would recommend you atleast call and speak with Harry about what he has found. Being the guy he is, he will give you his honest opinion even if you don't decide to have them do any work for you.
I will say this, the Stage-2 cam "looks" (by specs) to be the best available cam, where specs are available. There is a DEFINITE need for better "drag race style" cams for the Rap.
Swy
Old Oct 18, 2002 | 05:22 PM
RacinJason's Avatar
I have nearly the same set up and am running the stage 11 cam without any head modifications...although it could certainly use the port work...it still runs GREAT...and has more potential. The valve guide machining is easy and only neccesarry on some raptors. Go for it. BRAAAP!
Jason
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Huntingdeer
Aug 23, 2015 12:06 AM
