What is your dirt drag setup?
I need some better tires/rims for dirt dragging. My light butt, at 115lbs, I don't get too much traction. I have Kenda dominators on stock wheels right now, 20in with 14/40 gearing. I don't want to loose my top end at all, or my acceleration. I just need better tires. I was thinking of going with 22in Maxxis 4-snow's, with 10in .125 rims. What gearing changes should I make with those, and will I need to cut my heel guards? Any other tires? Are those any good?
What is your setup?
What is your setup?
Pro Wedge 2s are what I see most people running. They have a little less tread, but than the regular Pro Wedges, but they are a lighter tire. If you think the gearing you have now would be right, I would try changing one tooth, one less.
well ya see, i have Some Hard Terrain Duro tired on stock rims, they work pretty good when i hang my a*s off the back and my head over the front.[img]i/expressions/face-icon-small-wink.gif[/img] heard some good things about the pro wedge 2s like ward said.
88 Warrior
Pro Curcuit T-4
K&N Filter
Pro Design Intake
Jetted
DP Racing Brake Pads
DG Alloy Series Nerfs
Duro Hard Pack Rear Tires
New Plastic
New 98 Bottom End
Fresh 88 Top End
99 Blaster
FMF Fatty Gold Series Pipe
FMF Power Core 2
88 Warrior
Pro Curcuit T-4
K&N Filter
Pro Design Intake
Jetted
New Plastic
New 98 Bottom End
Fresh 88 Top End
99 Blaster
FMF Power Core 2
