blaster problem
Old Nov 16, 2002 | 09:33 PM
miniblaster's Avatar
Default blaster problem
hey guys i'm having a litlle problem. I have an 02 blaster with a few mods, and i don't know weather i'm running it to hard or not. I am really having this problem on hillclimbs. if you have any ideas pleas help. thanks
Old Nov 16, 2002 | 10:50 PM
blaster19's Avatar
What is it doin?
Old Nov 17, 2002 | 12:00 AM
It's like i spin to much, but my freinds say i need to run it harder and i'm really confused about why i'm spinning
Old Nov 17, 2002 | 12:04 AM
YFZRacer's Avatar
first of all is this like going about hills or what how old are your friends
what gear you usually clime hills? are these like dirst hills or sand dunes or what
Old Nov 17, 2002 | 12:10 AM
mainly on dirt hills, i have tried alot of different thing, i've tried doing it in low gears and high gears, but all i can do is spin. I'm 17 and i ride with a bunch of 17 or 18 year olds. The only problem is i'm the only 2 stroke. I think i need to run it harder at the bottom and get more of a run.
Old Nov 17, 2002 | 12:22 AM
I like spinning, but its almost like ther eis something wrong. I'm not sure what i should do, it runs great except for on hills
Old Nov 17, 2002 | 12:31 AM
YFZRacer's Avatar
ok since your a 2-stroke the power getting to the ground is going to be a little different then a 4stroke. 4strokes generally hook up a lot better then 2 strokes because of the way the power comes on with 4 strokes its smoother. Obviously more speed means more momentum meaning that you'll go farther up the hill but you should have to hit many hills in 6th to make it up. I think that just since you're comparing it to 4strokes it looks like your spinning to much 3rd or 4th should be enought to get up most hills. or if there more of a technical steep hill you want to go to a lower gear like 3 or 2. I don't have as much experience going up dirt hills but i know in the dunes a lot of times you may have to shift down to keep the revs up or feather the clutch a bit. A lot of it is just practice. what quads exactly are you comparing yourselve to cause if its like raptors or something they are going to clime higher then you cause the got way more power hope that helps a bit
Old Nov 17, 2002 | 12:32 AM
YFZRacer's Avatar
Old Nov 17, 2002 | 12:35 AM
yea thx i realy appreciate it, i just get worried cuz i don't want to blow it up or nuthin
thx
Old Nov 17, 2002 | 08:42 PM
YFZRacer's Avatar
no problem sorry for the double post
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
