what mod next for shee!
Old Nov 18, 2002 | 11:24 PM
albaBANSHE's Avatar
Default ***PAINTBALL***
i am lookin for somthing that i can do to my shee but what,all in put welcom!!!!!!!!!!!!!!!!!!!
Old Nov 18, 2002 | 11:31 PM
87Banshee250sx's Avatar
Default what mod next for shee!
maybe get your head milled 30 or 40 thousandths. Would increase HP and compression. Maybe turbo head mod from trinity, or new clutch. Maybe get ported reeds?
-nick
Old Nov 19, 2002 | 12:22 AM
RoostKing's Avatar
Mill the head, Advnace the timing and get your flywheel shaved. You can do all this for less than $150 bucks, and I guarantee you wont get a better bang for the buck..
RoostKIng...
Old Nov 19, 2002 | 12:24 AM
YFZRacer's Avatar
ya next step would be porting and bigger carbs and you can throw in the reeds and that other stuff
maby a new piston 2
oh ya andvance timing is i agood idea 2
Old Nov 19, 2002 | 12:29 AM
MichaelAZ's Avatar
Honest to god, I shaved the heads,advanced the timing,lightened the flywheel NO PORTING whatsoever and ask Roostking, it beats ported banshees ,albiet it aint beating a race port or alky but for what I have in it ,you cant go wrong. I do believe those mods did cost more than $150 , Im thinking $600 ??
Old Nov 19, 2002 | 12:32 AM
albaBANSHE's Avatar
i am gettin pro design cool heads for christ mas, but i want somthing good ansd cheap! like porting
Old Nov 19, 2002 | 01:02 AM
RoostKing's Avatar
Didnt Ken do more than that for $600? Oh yea, he added the v force reeds at $250, plus labor.
RoostKing...
Old Nov 19, 2002 | 01:05 AM
RoostKing's Avatar
Skip the cool head. If you shave yours you get the same benefits(the cool heads do not really run any cooler) Go with what i said and some porting.. See All of us who were earlier trying to get you to not buying a new banshee cause youd soon be modifying it anyhow. If youd have bought a used one, you could have had a PORTED< BIG BORE, PIPED< Graphixx/or Fullbore plastic, suspensioned banshee for less than what you paid for your ride.
RoostKing...
Old Nov 19, 2002 | 12:54 PM
WyoDuner's Avatar
alba, you only have a few other things you can do before going to a whole different level.. How much you want to spend is the real question.
So here's what you can do: mill your head, advance your timing, get a MegFlow impeller to keep things cool, remove the POS TORS before it starts causing problems, and MAYBE V-force reeds if you got over $200 burning a hole in your pocket. That's it before you have to tear your engine apart. About the same place I am now.
Next level involves porting and the mandatory welded crank.
Old Nov 19, 2002 | 01:03 PM
Peltrax's Avatar
What exactly is milling the head and what does it do?
