backfire thru carb ! need help !
Old Nov 30, 2002 | 11:06 PM
FRANCO's Avatar
Default backfire thru carb ! need help !
I have a 01 big bear that has a small problem, it backfires thru the carb. I have changed the sparkplug and taken the carb apart and cleaned it out and checked the valve gap. the bike runs fine aslong as your not at idel. has any-one experienced this problem and how did you correct it? It seems to be getting worse the more I ride.
Old Nov 30, 2002 | 11:08 PM
velocityraptor's Avatar
Sounds like you need to downsize your pilot jet, looks like your running rich! JMO
Old Dec 1, 2002 | 12:29 AM
swytak's Avatar
With that statement, it would make me think you have an intake leak.
Old Dec 1, 2002 | 04:56 AM
hardlydangerous's Avatar
Sounds like a lean mixture caused from either an air leak or too lean of mixture screw setting.
Remember the colder the weather gets the worse it will be as well. Start the bike and spray around the intake boots and seal and carb with a carb cleaner and listen for the idle to drop if it does you have a air leak. If it check ok try richening your mixture screw 1/4 to 1/2 turn out more.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
blpersinger
Jul 15, 2015 09:56 PM
