GRIZZLY WILL NOT SHIFT !!!!
Old Dec 6, 2002 | 09:00 PM
VAGRIZZ's Avatar
Default GRIZZLY WILL NOT SHIFT !!!!
Hello All,
I have a 2000 Grizzly, I went out to ride today and the Grizzly will not go in to any forward gear. Everything worked fine the last time I used it. It will back up but will not go in to low or high. It is like there is something stopping the shifter, I took off the plastic cove where the shifter linkage is and nothing in the way. PLEASE HELP I want to ride...
Thanks Vance
Old Dec 6, 2002 | 09:38 PM
Quadfather's Avatar
The 99 and 200 Grizzs were known for "shifter freeze" when it gets cold out. See if you can get some heat to the shifter linkage for a bit. It should help.
Old Dec 6, 2002 | 09:43 PM
VAGRIZZ's Avatar
It is COLD for sure here. Where do I try and heat it? I took off the shifte ball and boot to look inside and see if anything was wrong in there. Looked okay. I also took off the plastic cover that covers the shifter rod from the shifter to the case in the reat all looked good there to.
Thanks for your reply!!!!!!!
Vance
Old Dec 6, 2002 | 09:55 PM
Quadfather's Avatar
My buddies 99 Grizz does the same thing. It wouldn't shift in the cold. We took it apart and found nothing. Heard somewhere about the cold issue. We stuck a hair dryer on it for a couple of minutes, and bingo. Once you ride it for a couple minutes, the engine heat will keep it from happening again.....for that ride. Try it and let us know. I've been wrong before, just telling you my personal experience.
Old Dec 6, 2002 | 10:01 PM
RINCON's Avatar
My kodiak didn't want to shift in the cold either (the shifter would move, but the bike would not!)
Just the heat from the motor will be enough to heat it up, leave it in neutral, or if you're in a hurry get a hair dryer and heat everything in the general area.
Speaking of yamaha's, and freezing, my choke always freezes!! what a pain!!!
Old Dec 7, 2002 | 04:00 AM
RockyQuarry's Avatar
No kidding???
I wanted to get a Kodiak450 next spring. We ride alot in the winter here in Minnesota and it does get a bit below the freezing point. Maybe I should reconsider?
No such problem with present bikes.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
BigCam
Sep 16, 2015 01:53 AM
Elkaholic
Sep 6, 2015 02:44 PM
