JETTING MY WOLVERINE
got a bullet proof deal for wolverine carbs---96 and later--use a white bros torque valve and any pipe you want----carb---drill main jet out to between .056---.059 thousands---raise the needle 1 clip---fourth from the TOP--drill the air relief hole in the bottom of the slide out to between .116 -- .120 thousands--- not the one the needle goes thru --but the one to the side--put it bck on ---set low speed mixture at around 3 turns out --depending on your altitude and GO GET IT---proply done 50 of them---don't even test ride them anymore---k's it's gonna work----KEEP IT ON FOUR
