Wolverine parking brake
Old Apr 7, 2000 | 10:16 AM
musclford's Avatar
Mine will spit and sputter as well but I can still run with it on. I'm not sure why it cuts out, must be a rev limiter. Anyone know for sure?
Thanks,
Old Apr 7, 2000 | 11:11 AM
jcsact's Avatar
I don't know if you would call it a rev limiter. But there is an electronic switch on the top off your brake that controls it. I asked the dealer and he said it was a safety switch. So you remember to turn off the parking brake.
Old Apr 8, 2000 | 12:39 PM
95TimberWolf's Avatar
did u ever try adding aftermarket brakes on it? becuase from what i have heard and from experience Yamaha's brakes are pieces of ****. i dont know if this will help u but that is what i think. i hope u get ur problem solved!
Old Apr 8, 2000 | 11:14 PM
XLR8's Avatar
The '96 and up Wolverines have a switch that cuts the rev limit when the brake is on, since it was a problem on the '95 model.
Old Apr 10, 2000 | 12:22 PM
  #15
Harold's Avatar
Yes it can, tighten the adj. bolt until you can't move the atv, then lossen the bolt 1/8 turn. The reason you have to adj. the parking brake OFTEN is due to dust,dirt and mud getting on your caliper and eating the pad!!! I would think this is a normal condition for disc brakes.
Old Apr 10, 2000 | 12:43 PM
  #16
Bruce's Avatar
I had a problem with the brake switch. It would act like a rev limiter even when the brake wasn't on. Heres the fix. Just take the switch out and groundf the wire to the frame and the safety switch is gone. A better parking brake is to carry around a velcro strap and wrap it around the front brake lever. That makes for a much stronger parking brake. I do this when hauling my Yamaha's
Bruce
2000 Banshee
99 400ex
99 wolverine
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
