Exhaust Leaking??
Old Dec 16, 2002 | 09:26 AM
WarriorMan05's Avatar
Default Exhaust Leaking??
I have a Trinity Exhaust on my Blaster, not sure what coupler. It is leaking some out of the coupler though, should I just go get a new coupler or what?? I dont really mind it, but I just want it fixed if it can be fixed.
thanks,
Josh
Old Dec 16, 2002 | 03:38 PM
Blaster96's Avatar
I would clean the surface very well and then apply some hi-temp silicon between the two surfaces.
Old Dec 16, 2002 | 11:27 PM
iamchad2k5's Avatar
is it where the pipe reaches the silencer? or right out of the engine?
Old Dec 16, 2002 | 11:38 PM
GregV's Avatar
If it's leaking at the head pipe, make sure that you have the little brass washers in there. If your not looking for them they can come off with your old pipe and you didn't realize it.
Just a thought. You do want to fix it though, it no good to be running around with a leak.
Old Dec 17, 2002 | 09:17 AM
It's leaking out of both places; the coupler, and the head pipe. What are you talking about little brass washers, can I just get them from the Yammy Shop? Thanks for your help
Josh
Old Dec 18, 2002 | 11:40 PM
GregV's Avatar
Yes, the round brass washers that go between the head pipe and the jug. I had the same problem. One stayed on the engine and is probably laying on the floor at the Trinity shop and the other stuck to my old head pipe. I put everything back together and had the leak. A couple of calls to some area dealers and I was back in busness.
Old Dec 18, 2002 | 11:59 PM
GregV's Avatar
Right here Buddy...........Item #6
Old Dec 19, 2002 | 12:50 PM
Thanks man
Old Dec 20, 2002 | 07:43 AM
GregV's Avatar
No problem. I hope it helps.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
