Sprocket Changes?
Old Dec 17, 2002 | 05:22 PM
WarriorMan05's Avatar
Default Sprocket Changes?
On my Blaster, I have stock tires, it is jetted, with airbox mods, and then the Trinity Pipe. what I was wondering is if I should change the front sprocket, and if so by how much?
Thanks
Josh
Old Dec 17, 2002 | 07:19 PM
Reekster's Avatar
General Rule of thumb to help you out. 1 tooth change in front = 3 tooth change in the rear. 1 tooth down in front will give you more torque but you will loose a little in the top end. More teeth in front gives you less torque but more top end.
If you go down more than 1 tooth in the front expect to see more wear on your chain but you can use your same chain. If you want more torque and go up on teeth in the rear then expect that you may need to buy a new chain to meet the increased length. You may be able to add a master link to you chain to gain length without buying a new one.
Old Dec 17, 2002 | 07:43 PM
Thanks, another question. What is the stock sprocket in front and rear for the Blaster??
THanks Again,
Josh
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
