welding banshee crank?
Old Dec 18, 2002 | 12:33 PM
PilotYFS's Avatar
Default welding banshee crank?
i have a 2002 banshee with pipes, jet kit, timing plate, and the head has been milled .030. How many mods before i need to have the crank welded? How long before it will start to seperate?
Old Dec 18, 2002 | 01:12 PM
AlkyBurninX's Avatar
I have heard of 99's and 00's that have started to seperate. However, I have a friend that has raced his 96 since it was new and has never had the crank out. It is ported on race gas etc. Basically, wait until the bearings go or you have it ported. My 99's bearings were already shot in 2001.
Old Dec 18, 2002 | 05:45 PM
Jennifer's Avatar
I have a 93 and havent done anything other than fixing the counter wieghts that were coming loose on it a few years ago. Running about 175 lbs of compression and have luckily had no trouble with the bottom end so this point. I have pretty much the same stuff you listed plus a bundle more. But yes as Alky said I have seen 00 and 01 cranks come apart. Im just lucky I guess.
Old Dec 18, 2002 | 11:22 PM
00Banshee's Avatar
Before the power valve setup, I was running all the bolt ons with my stock cylinders at 185 PSI. I didn't race it just rode the dunes and trails. When I tore it apart to have it ported I found the crank had started to spread already. (this is on a 2000) I hadn't been running that PSI for that long either. If you start to feel any extra vibration done low I would check it out. If the crank goes it usually will destroy your top end as well.
BTW....Nice avatars everyone [img]i/expressions/face-icon-small-happy.gif[/img]
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
