rap jetting
rap jetting
I had simmilar problems on my 300ex it was kinda like it was going to die untill you got it past the point in the powerband. I had my air screw turned out 2 1/2 then I put it at 1 1/2 it solved the problem. Turn your air screws in 1 turn. If it still does it after that change your clip 1 notch lower so you raise the needle.
rap jetting
Thanks for the help. I did the change u said(2 steps up from the bottom on the clip and 1 3/4 turns on the air/fuel). my pipes are glowing red now at low rpm's, but are fine at idle. can't ride it due to the rain so i don't know how it runs. Going to pismo this weekend, so i want all i can get from my bike. [img]i/expressions/face-icon-small-happy.gif[/img]
