686 with stock rod, what comp piston is everyone using?
Old 01-01-2003 | 12:43 AM
AdamsBadDS650's Avatar
Default 686 with stock rod, what comp piston is everyone using?
I have heard that if you shouldn't go higher that 11:1 with the stock rod, but I know quite a few 686's with 12:1, and even 13:1 compression. Is it ok?
Old 01-01-2003 | 05:32 PM
Ernie660R's Avatar
The stock rod should be fine up to 11:1 or 12:1 compression, I use a JE 11:1 piston on my stock bore 660 and have no problems. Its a toss up between the stock rod and a aftermarket. Price wise keep the stock rod, if you plan to run 13:1 compression and shift at 11000rpm then get a aftermarket rod.
Old 01-01-2003 | 10:48 PM
Ernie660R's Avatar
OK, theres one that failed, maybe it would be a good idea to get a aftermarket rod for piece of mind[img]i/expressions/face-icon-small-shocked.gif[/img]
Old 01-01-2003 | 11:25 PM
Too much $$$ for me, staying with stock. I might regret it, but oh well, you only live once [img]i/expressions/face-icon-small-smile.gif[/img]
exmotocrosser
09-13-2019 07:12 AM
dannytas
09-26-2017 07:31 PM
2many2ride
09-27-2015 05:35 AM
Quadzilla Heritage
09-25-2015 02:39 PM
Todd C Wadas
2) Chassis problems..
09-24-2015 12:31 AM
Quick Reply: 686 with stock rod, what comp piston is everyone using?
