Raptor Troubleshooting
Old Jan 3, 2003 | 05:10 AM
Zombie66or's Avatar
Default Raptor Troubleshooting
Xtreme, I had the same problem with my 2001. Take your seat off and the black box behind your battery, the CDI. Tap on it and she'll pop right off. I cleaned the hell out every connection to the Box. The only thing that worked was smackin it with the screwdriver. Good luck.
Old Jan 3, 2003 | 05:22 AM
McFly's Avatar
Same problem here.......RED positive terminal connection came loose.........goes "klank" when you try to start.
Old Jan 3, 2003 | 03:53 PM
garyc660R's Avatar
I had the positive terminal come loose multiple times. My last "no start" problem was when I installed the engine (when the tranny imploded) and did'nt attach a wire correct and smoked my relay. Mine had the clicking as you speak of coming from the relay and the fuse was perfect. I could still push start and ride fine. I changed the relay and all was fine....about $30.
Old Jan 3, 2003 | 07:01 PM
MichaelAZ's Avatar
Mine is dead at the shop right now with those exact conditions. The starter spun as if it wasnt engaging, I pull started it and on the way back to camp , it died, now nadda,it just makes a large clicking sound at the relay, but I checked my fuses, my shop was thinking starter or strarter clutch ?? You guys think the relay ???
Old Jan 3, 2003 | 07:18 PM
  #15
sixsixT's Avatar
If it died while you were riding, it might be your charging system. Have you tried charging your battery?
Old Jan 3, 2003 | 07:26 PM
  #16
MichaelAZ's Avatar
No, because it was spinning making the dreaded whirling noise and wouldnt engage the strter or should I say the strter wasnt engaging, checked bike @ camp, piston would turn over , at least it wasnt the crank, this is my second one, the first died a horrible grinding noise.
Old Jan 3, 2003 | 07:39 PM
  #17
XtremeRaptor's Avatar
OK guys here goes: The gentleman who did my piston and cam install thinks the connecting rod may have let go!![img]i/expressions/face-icon-small-sad.gif[/img] I hope he's wrong!!! Thanks for all the info and insight!!!!!!! I will let you guys know EXACTLY what's wrong when I find out!!!!! Xtreme
Old Jan 4, 2003 | 01:29 AM
  #18
Anybody else have the same thing happen?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 4, 2003 | 04:15 AM
  #19
raptor8's Avatar
cross yer fingers... heck, cross everything! good luck
[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jan 5, 2003 | 12:15 AM
  #20
14mins's Avatar
Rigo- Well??? do the motor blow??? That is a pisser. Did the motor guy bore and hone the new piston or just slap it in???
