Who all in here has a ported banshee?
Old Jan 4, 2003 | 10:25 AM
2001PatriotBanshee's Avatar
Default Who all in here has a ported banshee?
Who did the work? any timed runs? what all did you have done?
Old Jan 4, 2003 | 10:57 AM
PatsRaptor's Avatar
My freind just had his 2001 banshee done at Mission Yamaha. Had full boost porting for more bottom end and port and polish and at the same time new top end milled head .070 no air box with K&N clamp ons and a V force. The bike rips hard everywhere. He saw the Mission Yamaha banshee in Dirt wheels called them up and talt to the owner he answered ALL his questions and so he liked what he heard and had them do it and LOVES what it did to his bike
Old Jan 4, 2003 | 11:23 AM
Hows it run against your raptor and what is "THE COMPOUND"?
Old Jan 4, 2003 | 11:29 AM
ct330's Avatar
i had a trail porting done and it made just as much diff. as the pipes did when i first put them on
Old Jan 4, 2003 | 11:34 AM
PatsRaptor's Avatar
My raptor is just piped and he will walk away from me and he wieghs 125lbs more then me..
theatvcompound.com
Old Jan 4, 2003 | 11:43 AM
Imback's Avatar
I own a T-REX top end that has been ported by Rossier Engineering in Wisconsin, i also own a stock bore top end that has been ported by 4 Wheel Thunder in Michigan.My next set up is a Cheetah top end with a 4 mm stroker crank all done by Patriot Racing in the state of Washington...Should be fun.
Old Jan 4, 2003 | 11:53 AM
Isnt that T-Rex cylinder supposed to produce 140hp?!?? What is the Cheeta? is that Trinitys PVL?
Old Jan 4, 2003 | 12:05 PM
Imback's Avatar
The T-rex top end or more commonly known as the FMF PV cyls can produce very big numbers if set up correctly, i dont know if 140hp is reachable but i have seen 120hp with the correct set up.The Cheetah cyls are a creation of Calvin Pollet and right now they are the best aftermarket cyls you can get due to their revolutionary transfer ports desing, they are better desingned than even the T-REX cyls they produce more HP than anything outhere, you can get as much as 140hp out of them in thier most extreme configuration.Trinity along with many others sells them but they didnt by any means create them.
Old Jan 4, 2003 | 02:00 PM
YFZRacer's Avatar
my dads got the national pipe and porting kit from duncan racing works good
Old Jan 4, 2003 | 04:25 PM
pudjumper's Avatar
I been looking at this for awhile.....http://www.twistercrankshaft.com/news.htm
