stumble or chuggle
Old Jan 7, 2003 | 01:34 AM
jraptor's Avatar
Default stumble or chuggle
when i feather the throttle a low rpms the engine sputters & sometime stalls or pops
i cant lug the motor at all ????
full yoshi exh,160-165 main jets 25 pilots,open airbox + k&n
top clip on the needle
Old Jan 7, 2003 | 10:06 AM
sixsixT's Avatar
Try putting the clip on the third groove of your needle. 2 turns out on your idle screws.
Old Jan 7, 2003 | 10:08 AM
garyc660R's Avatar
Definately move the clip down, which effectively richens up mid range. Start with the 3rd notch from the top with no lid.....and test.
Old Jan 7, 2003 | 03:28 PM
Chimmer's Avatar
Yup I agree, low end stalling due to hard hesitation is a lean condition. I 've had that a problem a few times when the weather/temp changes & I cured it with richening the fuel screws. At least 3 turns out each is a good place to start. I got tired of playing with the fuel screws so I installed 25 pilots & leave screws around 3 turns each in winter, maybe 2.5-2.75 in summer. I also noticed the Rappy likes the clip up higher since most airbox mods actually richen the low/middle end due to slower air velocity. Too much air gives great mid/top end but causes low end air velocity/turbulence. I run with the clip on pos 2 or 3 depending on temp/weather.
Old Jan 7, 2003 | 04:05 PM
RacinJason's Avatar
after the weather change the past few weeks my bike has leaned out considerably try needle adjustments
BRAAAAp
Old Jan 7, 2003 | 07:20 PM
ba01raptoraz's Avatar
Mine used to do the exact same thing so I raised the idle just a hair and problem solved. There was an article in ATV Sport or something other than DW talking about people blowing the carb boots off. The main causes were a lean condition, not warming up the engine properly, and last but not least, too low of an idle. I tried the latter and never had a problem since.
Old Jan 7, 2003 | 08:30 PM
velocityraptor's Avatar
I 2nd this.
Jmuddin284
Jan 19, 2026 07:16 AM
neilbedwell
Nov 10, 2018 11:02 AM
Jul 30, 2015 09:39 AM
derbyking
Aug 17, 2001 12:33 AM
JIGA
Oct 30, 2000 01:28 PM
