What to do? Stroker or bore kit? HELP!!
Old Jan 10, 2003 | 01:33 PM
fourjs's Avatar
Default What to do? Stroker or bore kit? HELP!!
I have a 2000 Warrior that needs to have the rod bearing in the crank replaced, I would like to get the cc to app. 400, would it be better to get a stroker crank rebuild (one from Powroll or 4-stroke tech) or keep the stock stroker, after fixing, and get a bore kit, ?? Mostly confussed on what to do, 90% of riding will be in sand,
Old Jan 10, 2003 | 01:39 PM
JakalWarrior's Avatar
I would probably get a big bore kit since strokers have more things that can go wrong. Just wondering, howd u kill the bearing?
Old Jan 10, 2003 | 03:53 PM
fourjs's Avatar
To be honest, I am not sure, went up a dune, it started making this noise, piston was hitting the top of dome, and a noise was coming from down under, took it in, this is what the guy told me, I am not sure of the bore kits, cranks, what to do, just thought I would ask, since the have to split the case anyway, thought I would look into more hp/cc, but did not know which way to go..
thanks for the reply.... ..
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
