I'm out. FSW
Old Jan 12, 2003 | 07:55 PM
Ward660R's Avatar
Default I'm out. FSW
GregV is was barely on the throttle, turning from dirt to pavement.
Thanks for the advice King. It is turning over but doesn't have enough compression to start. There is NO water in my oil.
I just thought of this. The upper radiator hose was leaking earlier in the day. I waited until it cooled down slid it up on the neck, on the motor, a little. When I did this some water came out of the hose. Some how could this have air locked the head and then it gotten too hot? Just a guess.
Old Jan 12, 2003 | 08:03 PM
miniblaster's Avatar
wow, i'm sorry to here that man, good luck
mini
Old Jan 12, 2003 | 08:38 PM
AlkyBurninX's Avatar
Ward, the air lock idea is a possibility. I fried a new piston on my polaris due to air lock. I put the engine together and started it up to pump water through. The radiator stayed full until I took off down the road and it melted the rings to the piston.
Old Jan 12, 2003 | 08:45 PM
RIDEORDIEYZF's Avatar
Sorry to hear about that man.
How do you avoid "air lock". I just don't want to happen to me when i get mine all back together.
Old Jan 12, 2003 | 08:48 PM
  #15
14mins's Avatar
waard- load up and come on. I have enough piston/cams/gaskets/valves/seals/carbs to rebuild 20 raptors. Maybe rrc or somebody can put it back together. MAKE IT HAPPEN
Old Jan 12, 2003 | 08:51 PM
  #16
Raptoryfn660r's Avatar
RIP Dear Friend
Wow!!!!!!!!
Old Jan 12, 2003 | 08:52 PM
  #17
desracers's Avatar
Ward, go for it since 14min and other peoples want to help you and head for FSW..... You won't regret it at all.... at least you came out to FSW....
Old Jan 12, 2003 | 09:08 PM
  #18
RaptorRcR's Avatar
Ward..what piston/bore are you running? If you holed a piston, let me know. I have a few spares. I also have a 696/697 cam and a stage II hotcams in case you busted you cam. Let me know if you need these and I can overnight them or 2 day them to you so that you wont miss out on FSW's 2.
Old Jan 12, 2003 | 09:13 PM
  #19
PatsRaptor's Avatar
Even if you just go with the bike I will help on the wrenching
Pat
Old Jan 12, 2003 | 09:23 PM
  #20
Ward660R's Avatar
Thanks alot you guys!!!! Really, I appreciate everybody stepping up to help.
I am waiting on a phone call from 14mins about trying to do it there. I'll let you all know when I find out.[img]i/expressions/face-icon-small-smile.gif[/img]
If this does go through I am going to owe a couple people BIG TIME!!!
