I'm out. FSW
#63
If there is water in the cylinder still your screwed anyway by the time frame, I am sure ward checked this as soon as it happened. The cracked head by te water jacket sounds about right. ouch! Well anyway good luck to all.
#65
Ward,
If you have time you could remove the intake valve cover and spin things around until you can see the decompression pin. Give that a look see and you can rule out the assumption I was having. If the pin is fine, no damage etc, then my question about the cam etc is moot.
#68
Lets just hope that it isn't the spark plug boot that cam off
wshrdskin, I tried that but couldn't really see the pin that well, not at all actualy. Of course that is when I was steaming right after it happened so I might have just missed something. Nothing in the valve train looks trashed or bent, so that might be a good sign. I just pray that its not a cracked head or cylinder, anything else I think we will be able to fix there.
This is my last post before I leave, I think.
To all that have helped me again THANK YOU.
To all that are not comming, sorry.
And to my wife, who will be at home, I'll miss you and I love you.
I'll see the rest of you on FRIDAY!!!!!!!!!!!yipeeeeeeeeeee!!!!!!!!!!!
