raptor starter clutch problem's ????????
Old Jan 13, 2003 | 09:21 PM
czoid22's Avatar
Default raptor starter clutch problem's ????????
my 2002 raptor one way starter cluth went out and its ony 6 months old every one else having problem's with this thing??? the same thing happened to my freinds raptor so thats 2 that i know of..........
Old Jan 14, 2003 | 12:24 AM
raptor8's Avatar
YES a weak spot on this quad. have heard lots of ppl changing them, not mine yet.
heard there was an updated design, but cant confirm that.
sorry about yer luck./
Old Jan 14, 2003 | 12:46 AM
Raptoryfn660r's Avatar
RIP Dear Friend
I haven't had any problems either.
Old Jan 14, 2003 | 07:31 AM
RaptorForever's Avatar
Mine went on my Rap about 3 weeks after I got it. The bolts actualy fell out and into the case. Yamaha stood behind it and paid for the fix.
Old Jan 14, 2003 | 10:01 AM
garyc660R's Avatar
Yep, definately a trouble area for the Raptor. WHen the 1-way assembly does go out, it sends a thousand fine particles through your engine...these particles are form the spring inside the 1-way assembly that break so often. SO, when you are cranking the engine over, if the starter seems too "free-wheel" and then slam in...turning the engine over, or you hear a load grinding noise, the problem needs too be addressed immediately. Mine has been replaced once by Yamaha (parts only...I changed it out) when out of warranty. I try not too start the engine while in gear, because the clutch drags on the rap adding more pressure on the 1-way assembly and this increases the likelyhood that the engine could kick back when the engine is turning over more slowly...again, adding more pressure on the 1-way assembly.
Old Jan 14, 2003 | 10:08 AM
RoostKing's Avatar
Talk to MichaelAZ he can help
RoostKing...
AtvManiac78
Jul 11, 2015 03:20 AM
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
