NEED HELP RIGHT NOW
Old Jan 15, 2003 | 12:15 PM
iamchad2k5's Avatar
Default NEED HELP RIGHT NOW
yeah, ill get new floats. but the problem remains is the little needle sticks. so i guess i spray the crap out of it with the carb cleaner. the rest of the carb looks beutiful though.
Old Jan 15, 2003 | 05:49 PM
iamchad2k5's Avatar
i took the float off. and compared it to the 400. the 400 size float was the exact same. so i switched them. it still leaks gas. not much though. but i took the carb off so i could burn up any gas that was in the engine. i kicked it a few times, and a few more, than it started, and then died and burnt the gas up inside the engine. i put the carb back together, sprayed some carb cleaner in it. kicked it and it started. i rode it around. and its cool. now all i need to do id put the new clutch plates in it. and the air filter. hopefully it will run all the time now. lol
