new cdi box for raptor
Old Jan 18, 2003 | 01:19 AM
kobe's Avatar
Default new cdi box for raptor
does any body know about a cdi box that can allow the raptor to rev to 11,000 rpms or 10,000 rpms because if it could it would de a nice little mod to have. thanx
Old Jan 18, 2003 | 01:37 AM
CTRaptor's Avatar
It wont do anything anyway. a stock raptor in 5th gear can hit 7k rpm max, piped around 7400 rpm and with a hi comp piston and cam around 7800 rpm. Thats probalby why no one makes one. unless of course someone else has a tach and hit higher revs than me. IMO its not needed.
Old Jan 18, 2003 | 01:39 AM
RaptorRcR's Avatar
CT...Dyna makes a CDI for the raptor. I dont know if the CDI raises the rev limit because I havent had time to mess with mine since I have no motor to run it on[img]i/expressions/face-icon-small-smile.gif[/img] But it does allow you to adjust ignition timing, and you can also program your own if you get the cable to do so.
Old Jan 19, 2003 | 01:44 AM
RaptorRacer1's Avatar
That is correct. The Dyna ignition box has 4 selectable timing curves. One is totally stock and has the stock rev limiter. The other 3 increase the timing and, I believe, have no built in rev limiter. If you get the programmable model and the programming kit i think you can adjust the rev limits on each curve.
RR1
Old Jan 20, 2003 | 11:41 PM
kobe's Avatar
thanx for your help
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
