35mm FCR or alcohol
Old Jan 18, 2003 | 01:10 PM
yamaha4life's Avatar
Default 35mm FCR or alcohol
ive been reading up on alcohol mods to a stock carb...seems simple enough to do,
but also considered buying the 35mm fcr's sounds like the alcohol would be a cheaper
way to go...i know you have to change the oil more often and re-ring maybe every year
but the extra hp should be worth the while Anyone running alky on rappy????
Old Jan 18, 2003 | 11:55 PM
anybody??
Old Jan 19, 2003 | 10:34 AM
Ernie660R's Avatar
Have you done any mods to your engine. If you have not it would be a waist of money to go to alcohol, no compression. If your buying 35mm FCR's again waist of money. An engine with little or no mods could not use the full airflow that those carbs put out. If you had a 727 then that would be a different story.
Old Jan 19, 2003 | 11:45 AM
they are coming with the 690 kit
Old Jan 19, 2003 | 12:07 PM
raptorveloci's Avatar
There is a set on Ebay for sale..
Old Jan 20, 2003 | 10:53 AM
AlkyBurninX's Avatar
How about the FCR's on alky?! The FCR is the best 4-stroke carb in my opinion and is easily changed to alky.
Ernie is right about the compression.
Old Jan 20, 2003 | 11:03 AM
i was going to put the stock one on alky to keep from buying the 1000 fcr's they supposedly only
add 3 hp dosent add up to me
Old Jan 20, 2003 | 11:05 AM
Ernie660R's Avatar
True, Very True!!!!!!
derbyking
Aug 29, 2004 10:44 PM
swytak
Jan 28, 2002 01:15 AM
j7273
Oct 11, 2001 08:03 PM
cspyy
Jan 10, 2001 09:00 PM
majicmike
Mar 15, 2000 09:53 PM
